- Apr 12, 2001
- Michigan ,USA
when using the DVI cable option does that disable some funtions on the OSD menu example the contrast and color adjustment? and the auto adjust says not available when I use the DVI, but when I use the analog D-cable everything is enabled. Is this right? There is nothing in the manual about it either,or on the web site....
