- Mar 1, 2004
- Vancouver (Canada)
I just made a new blowhole, and added some rubber grommets to dampen the sound
Unfortunately, the fan screws i have right now aren't long enough to go through the fan grill, grommets, and into the threaded corners of my fan
I went to my local hardware store, brought along the fan screws, but the guy i asked working there couldn't find me a longer screw that was the same size with the same type of threading
I'm wondering, is there a certain numerical size i can ask for at the hardware store? It would suck if i couldn't use my blowhole
Thanks in advance
(forgot to mention, i need the grommets for sure, because i added some chrome auto trim around the sharpness of the hole too, so the grommets make it fit well)
Thanks in advance
