Thanx. I'll try to give sufficient info...
Cpu-Z Report
Cpu-Z version 1.10.
Cpu Vendor GenuineIntel
Cpu Name Intel Pentium II (Deschutes)
Family / Model / Stepping 6 5 2
Cpu Clock 400.9 MHz
Clock multiplier x 4.0
Front Side Bus Frequency 100.2 MHz
Expected Cpu Clock 400 MHz
Expected FSB Frequency 100 MHz
Package Slot 1 SECC
Core Stepping dB0
Technology 0.25µ
VCC 0 0.128 volts
VCC 1 0.128 volts
IO_VOLTAGE 0.128 volts
L1 Data Cache 16 Kbytes, 4-way set associative, 32 bytes line size
L1 Instruction Cache 16 Kbytes, 4-way set associative, 32 bytes line size
L2 Cache 512 Kbytes, 4-way set associative, 32 bytes line size
L2 Latency 7
L2 Frequency 200.5 MHz
L2/CPU ratio 1/2
L2 Location On Cartridge
L2 ECC Check enabled
L2 Data Prefetch Logic no
L2 Bus Width 64 bits
Supported Instructions Sets MMX
Motherboard manufacturer First International Computer, Inc.
Motherboard model VB-601, 1.X
BIOS vendor Award Software International, Inc.
BIOS revision 4.51 PG
Chipset Intel i440BX/ZX rev. B-1
RAM Type SDRAM
RAM Size 128 Mb
RAM Frequency 100.2 MHz
CAS# Latency 3 clocks
RAS# to CAS# 2 clocks
RAS# Precharge 2 clocks
AGP Status enabled, rev. 1.0
AGP Data Transfert Rate 2x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 64 Mb
Don't know if this helps (messy copy-paste). I'm now downloading MBM... I'll reply within 24 hours. Sorry and Thnx
