- Jun 20, 2001
- Upstate New York
Ok. I currently am in possession of an 8K7A Rev1.0 and an 8K7A Rev1.1. There is only one difference that I can tell. While the heat sink for the north bridge remains the same, the fan has changed. The Rev1.0 has an AAVID fan, while the 1.1 has a Coolermaster fan.
Other than that, I'm noticing some differences in my overclocking abilities. I assume the difference can be attributed to one of three things. The differences are as follows:
The Rev1.0 had the July BIOS installed, where the 1.1 has the August BIOS.
I have a different processor -
Before
A1400AMS3C
AYHJA0123MPMW
K0073650175
Now
A1400AMS3C
AYHJA0125FPCW
Y6497930349
And also - the difference of the fans.
For some reason (although I have not changed RAM), my system is running stable with a 145mhz front-side bus now. (I've run Sandra CPU, CPU MM, and the memory benchmark. Then I ran the burn-in wizard with CPU, CPUMM, and Memory for 10 loops. Then I ran 3dMark2000 and 3dMark2001) Perfectly stable throughout these tests.
Before (With the Rev1.0) I could not even achieve a fsb of 140mhz reliably. I would experience a crash in Sandra's memory benchmark.
Does anyone have an ideas why this would be so? I'll post my full specs.
AMD Athlon T-Bird AYHJA (K before, Y now) @ 1.85v
512MB (2 x 256mb) Crucial PC2100 @ 2.5v
Toshiba 16x DVD-ROM
TEAC 1.44mb 3.5" floppy drive
Fong Kai 320ATX case (with their standard 300W PS)
SBLive! X-Gamer 5.1
ASUS V8200 "Pure" GeForce3
Western Digital WD800BB (80gig, 7200 RPM, ATA100)
Samsung SyncMaster955DF
Klipsch ProMedia 5.1 500w Speakers
Any ideas? I have no idea why it would change so suddenly, and so drastically. I'm talking about a 10mhz SOLID increase in fsb.
Before
A1400AMS3C
AYHJA0123MPMW
K0073650175
Now
A1400AMS3C
AYHJA0125FPCW
Y6497930349
Toshiba 16x DVD-ROM
SBLive! X-Gamer 5.1
