- Jan 30, 2005
- Texas, USA
Made from a Clear PC case turned upside down. Houses 2 Meanwell 320 12v psu's to power the TEC's along with a pair of EHEIM 1250 pumps. The pumps and relays are mounted on a sheet of plexi attached to the MB mounts via rubber vibration dampeners. There is a dual bay res with fill, drain and air bleed along with temp monitoring circuitry that control the fans. Cooled with a pair of Thermochill 120.3 rads and 9 120 mm fans with intake filters. Unit is powered on remotely from the PC and features a RUN/OFF/AUTO circuit. PSU's are cabled with 12 gauge monster cable to a terminal strip in the PC. A remote outlet on the rear lets me power up other A/C devices with the PC as well. Right now it's being used to turn on a third psu to supply 24vdc @ 8 Amps to the video card 172 watt pelt. This thing is capable of dissipating over 1000 watts and will heat up a room but runs amazingly quite.
