They can look really nice when designed properly, and really gaudy when not.
Many people go overboard with too many reactive components. And/or have no good
color scheme. Keep the colors separate or you get a white washed effect.
I used blue (lighting) and black (paint case all back) and have been using it for years. Still ppl ask why I used blue, heck its my favorite color and not many ppl used blue then.
I noticed there's no option for multi-colored. I've got a few tri-color LED fans and when I'm done with case mod there'll be other colors as well. No white or UV though.
If I were to choose a single color, probably purple.
Dammit. I should have voted yellow! I LOVE yellow and have my wires sleved blue with yellow connectors. Yellow dye for my watercooling. If yellow wasnt so bright ide have all yellow fans!
I tricked out my brothers computer with green/blue UV fans, a green LED fan and 2 purple LED fans that are close enough to UV that they make the UV reactive stuff glow. Then in the front panel I plan to put a 3-way switch to power 2 CCFLs in the bezel. One green and one purple of course depending on his mood. I already have the switch all wired up. Just need to cut something off the case to install the switch.
I chose blue, mainly because the only thing i'd pick over it is black Right now, though I'm operating with green because thats what is on my IC7-MAX3. Used to be I was utterly against case lighting, and I still mostly am, but accent lighting is not really overkill, I'll probally have blue eminating from under the motherboard in my next system, and maby from behind the PSU. Along with an encredable wiring job that will be all thats part of my case.
i cant vote cause i like blue with red aswell . it gives a nice contrast between the two with a hint of purple if placed in the right places p.s no im not a hippy..just coz i got long hair. dont mean nothin
