I have seen couple of threads in ADM/CPU section that have overclocked the 65w pretty decently. You probably are referring to the 35w version. I have read something to that effect on the 35w, but the 65w should do fine.MadMan007 said:I'd read on Tech-report that the low-power A64s don't oc as well. AMD altered the manufacturing to make them low-power, which is good for say HTPC or small enclosures, but has much less OC headroom than the normal x2s. Are there people who are getting the same OCs from the low-wattage CPUs? I don't read the AMD section every day.
Good to know. As said vid cards is not my department, so thanks for the heads up.Evilsizer said:fyi in case you did know och is that the 7900gto is a slightly down clocked gtx. imo well worth the 255 vs the 7900gt with only 256 where gto=512.
yep luck of the draw and depends on the quality of the batch of silicon. as oc's will change from batch to batch. i like the 35watt's for a nice passive rig though.ochungry said:I have seen couple of threads in ADM/CPU section that have overclocked the 65w pretty decently. You probably are referring to the 35w version. I have read something to that effect on the 35w, but the 65w should do fine.
But as we all know, not all cpu's overclock the same level. some do better than the others (same model but different stepping). If I find the thread(s) I will link it here.
These days there are so many good choices because of the price war and competition that we get lost at the end. Both platforms, Intel's core 2 and AM2's can make you a very nice system at the end and no regret which one you end up buying and have enough to spend it on a good vid card.Evilsizer said:yep luck of the draw and depends on the quality of the batch of silicon. as oc's will change from batch to batch. i like the 35watt's for a nice passive rig though.
MadMan007 said:Yes to your last question. Although I'm curious what evil means by 'with new nv drivers you can run quad sli' - do they only support two 7900GX2s? His first list looks nice, except I'd get a scythe ninja+ instead of the mine which has a smaller and harder to replace fan, and you may as well use your current PSU it should be good.
The nvidia Intel chipsets don't overclock well. As far as worrying about SLI/CF...meh imo it's only really worth it if you get two relatively highend cards practically right off the bat. The whole 'add another card later' thing makes sense if you get a second card soon, like within a month, but adding another 6-12+ months down the line with the rate new cards come out you might as well sell the old one and buy a new single card. This is especially true atm because by this time next year DX10 will have picked up.
yep nothing but these babiesyoungbuck said:Anybody got some good ideas for a HDD setup that will take advantage of the Matrix RAID? I think I'll just stick with 2 drives for now.
maybe but i would pass on the gx2 for a real sli setup of 2 7900gto's bios flashed to gtx's. same cards gto's are just down clocked a bit on the mem.BUtchM30 said:mobo
http://www.newegg.com/Product/Product.asp?Item=N82E16813123004
cpu with discount amdrocks code
http://www.newegg.com/Product/Product.asp?item=N82E16819103526
a 7950gx2 vid card and some g.skill ddr2 800 mem
its fun to imagine
Evilsizer said:maybe but i would pass on the gx2 for a real sli setup of 2 7900gto's bios flashed to gtx's. same cards gto's are just down clocked a bit on the mem.
i dont see why not saves you alot of money. since i cant see recommending the gx2 at all. besides the gx2 is really 2 cards but one slot, the sli'd gto's even in stock form will be faster. nv is still tweaking drivers for the gx2.youngbuck said:I think I'll opt out of SLI and just stick with a single card... then later down the road just buy a new card when dx10 is out for a bit.
If I'm going with a single card, should I just go with a 7900gto flashed to a gtx?
yea gto is the best bang per $ even better then 7900gt/7950gtjivetrky said:yeah, but from looking at the reviews, it's not really "all that", even with 2Ghz DDR4 ....I'd still go with the GTO if it was me.
