- Sep 18, 2005
Well, its been almost a week since I got my e8400. I got a Zalman 9700LED from microcenter due to them being out of stock of anything else when I went. I read the zalman is sufficient, albiet not the best.
However I am watching others and their temp postings, and I am starting to wonder if I am having not as efficient as I should results. The oc is simple at best, e8400 at 3.6Ghz. I am using a CM690 case with 6 120mm fans.
I decided to take these after i was 3 hours into a Orthos blend run so the temps could climb abit to better see if there is a issue.
Any opinions are welcomed.
