- Jan 7, 2014
- Munich, Germany
As it is, the circuit seems to want max 5K resistance which is why the 10K pot doesn't do anything above 50%. Argh!
connecting a 10k resistor in parallel should help
0.6v drop is quite good
by the way, you can use your case as a big fat heatsink for the IC
just make sure to insulate the IC properly
and that reminds me to the "open hardware monitor" (LINK)
really similar to the well known h/w monitor, but with open hardware monitor we can relabel FAN #1 to CPU FAN and such.
I also found the reported CPU temps (the "on die" CPU temps) were slightly higher compared to the h/w monitor.
I was wondering if anybody tried this open h/w monitor with modern AMD CPUs,
does it give any make sense temps report?
I see no difference between the two.
CPU-Z and HWMonitor are acting weird today though. HWMonitor doesn't show my voltages and CPU-Z reports a Vcore of 1.4 which is not true.
Temps are correct though. I know that for sure.
inVain said:your temps are surprisingly terrific for that 6 cores CPU @4Ghz+
Thanks guys!
I just quickly booted up Prime95 for that SS. Normally hits 50C MAX core temps. Temperature #1 is the socket temp. It will climb to within 10C of the CPU. #2 is the motherboard temps, it is usually 32C.
I can answer the temperature question on the AM3+ FX line.
The temperature diodes in the FX are only accurate once they hit +40C. It's not actually a die temp either, rather it's some sort of complex formula to the tjMAX temp of the CPU, 62.2C. Something like that. It's very bizarre...
Nobody knows why they did it like that... AMD Overdrive is the most accurate on these platforms, but it only lists the distance to the max temps. "Thermal Headroom" they call it.
No problem!This is the best answer I ever had.
Thanks a ton!
how about the APUs?
does the same answer apply?
I need to upgrade my system,
but these temps issues and the "minimum specs for OC" always hinder me to pull the trigger
edit:
about the tjMAX, does this mean that the AM3+ FX line were intended to never exceed 62.2C (safe operating temps were under 62.2C)?
