- Jan 9, 2013
Hello. I'm starting a new project here. What i plan on doing is modifying my Tower again for cooling. Tower is the Antec DF-85. I Am removing all the 120mm fans and replacing them with Delta AFB1212SH-PWM's. Side fan is going to be my PFC1212DE-PWM -T8SH. CPU Fan will remain my DBX-B. The stock Antec case fans are known for dying very fast. Fun part, the fans are PWM. I am building a PWM controller copying bings 556 schematic. It will be 3 controllers set up as 1. Front 3, 2. Back 2, 3 The Side delta. The special part, because i love switching between both my PFC1212DE and my Sayno Denki 9SG1212P1G01, i'm building the 3rd channel at 16Khz. The delta is rated to function between 30Hz and 30Khz, so it shouldn't be an issue(even though delta reccomends 25). I ordered parts today and started making all the cables. The PFC is going to draw power from the Molex rails and the AFB's will draw from the PWM controller using two floppy style power connectors. So far, i have made all 6 cables, and made one with a TACH wire for the side Delta. The Top 140MM fans are getting blue LED's to match my Intel DBX-B and my Asus P6T(to bad the GTX 570 is red, and the Corsair kit i have is red too. may do a different ram kit.) I am going to mount the PCB's in a broken CD drive case using the front Cd drive bay cover to hold the POT's. This may be very fun. I will start posting pics tomarrow when i get back tommarrow. First time posting here, hope we all get along
