- Nov 15, 2010
- Palm Harbor
I have a AZZA Solano 1000 computer case. want to replace some of the case fans cause they old and some are failing. and all of them are 2-wire that pluf into molex connector so they use full power all the time. the case has plenty of cooling so i would like to make it quieter by going PWM or at least reduce voltage
according to the specs, the top and the side fans are 230mm with blue led. there are also 2 front 140mm fans and a rear 120mm fan. so there is plenty of cooling. yet alone my water cooler had 2 addition 120mm fans. all the fans are dedicated 12v so its pretty excessive.
recommendations for 230mm fans? not sure if using a mobo header can handle a 230mm fan. would prefer blue or red, dont really need RGB tho. also is there a recommended brand fan for 140/120 fans that isnt too expensive?
AZZA Solano 1000 Black Computer Case - Newegg.com
Buy AZZA Solano 1000 Black Japanese SECC Steel/Metal mesh in front MicroATX/ATX/Full ATX Computer Case with fast shipping and top-rated customer service. Once you know, you Newegg!
www.newegg.com
