Hi alinosa,
Now with a 2100+ CPU you will need a Peltier of 200Watt or greater if you want any chance on hitting sub-zero. However even this peltier will struggle too with that CPU (even when not-overclocked).
I would head over to
www.wetandchillychips.com they have a 312Watt Peltier (that doesn't produce condensation!) And its for a reasonable price.
The only problem with a Peltier for your CPU is you will need a Watercooling setup just to cool the Peltier!! (The reason for this being the Peltier not only generates a few hundred watts of Heat but also the CPU's heat
) A HSF would simply overheat and the Hot Side would take over the cold side in seconds and well your CPU is now a "fixer upper"
I would also be careful with Peltiers as they are difficult to use, you may want to do a search on the Front Page for people who have used Peltiers before to see which techniques they employ.
Yes you will need a Cold Copper Plate for the Peltier as well. This goes directly on the CPU then the Peltier sandwiches on top, followed by the H20 Waterblock.
Also you need VERY HIGH Ampage PSU's, that 320Watt may well blow if you plug in a Peltier, and these high ampege PSU's can cost a bundle. ($100 and up)
Here are some useful links:
Water/Peltier Cooling Questions
Watercooling -- condensation problems?
Vapochill
Project X started...THIS IS A MUST READ
Cheap Evaporative Cooler in a Bucket
CPU Cooling with Dual 172 Watt Peltiers
I've included some "make your own" links for a more cost effective picture.
Or you could buy a Vapochill, they are expensive ($400-$700) but they almost guarrentee sub-zero temps. (They work on a phase-change system concept)
If you neeed info "Doctor" and "WildAndyC" both have them, just PM them for info and they will be glad to help. (Doctor hangs around the AMD Motherboards forum helping with Volt Mods, as for Andy well he's everywhere!!!)
If you need any more help then just ask!!!
Nick "Maximus Nickus"
