I think I have a high temperature on my cpu and I am looking for a way to cool it down.
I just upgraded from i7 2600k to i7 3770k. I used the same cpu cooler for i7 2600k and temperature was about 28-32C on idle and 58C at 70% CPU on 4GHZ overclocked.
I installed i7 3770k on same motherboard and same cooler, with arctitc silver5, then temperatue was about 97C. I do not know exactly the problem there. I tried several times, still same result. then I decided to put stock cooler. temperatue is now at 44C on idle at stock speed, room temperature 30C. I also opened the case lay it down with a fan blowing to it now.
can any body recommend at cooler maybe dual fan cooler or water cooling system or maybe a thermalelectric product for me? I need intel push pin type. I don't want to take motherboard out.
