- May 8, 2012
- Northeast Chicago Suburbs
Any link to how you got the fans to change color?
I can't put it better than those who have posted before, but here goes -- what an achievement in a build! It is a real dream setup in every way I could imagine. I like the exterior finish, and the color change of the fans is no small deal, way to go!! Corsair has a system that lets you control LED's based on load (the hotter your temps, the more red the fans get -- conversely, when cooler, the fans turn blue). But if you figured out how to pull it off, I'm going to try to copy from that rather than stuff their fan controller into my case.
I am curious as to how you programmed the switch to tell the motherboard which PCI-e lane to use. I would like to do something like that someday.
Thanks bluezero, I will have to look into BIOS programing. Although I am thinking it would be easier for me to mod toggle switches onto my case for each lane because I am particularly bad at writing code.
HD7970 benches better for many bench tests, and I do bench tests quite often. So I would like to have both in my system. I have a set of 'white' power cable for it that glows in UV light, however that messes up my photography to. didn't expect that when I bought it, it looks cool though, so when I take photos, I usually tuck that cable to the sides so I can emphasize on the water system instead. Maybe I can turn off the UV and show another photo of it under normal light... good idea.
Firstly, under the hood:
back active cooling is required with this VRM load.
Decent setup there
Question about this though, have you drilled vents in the side panel?
