I finally managed to get my brothers PC put together, installed some software on it, and was taking it for a test run with a few games, making sure everything was working properly.
Ran into an issue with Skype though and can't seem to find a solution online, or at least, None of the ones I found did anything.
Skype Automatically adjusts microphone volume. You can choose to turn this off in the options, but doing so, for me at least does nothing. Skype will still automatically adjust microphone volume, especially so when there might be a noise in the background it can hear when you're not talking(mine specifically is the traffic outside). So whoever is on the other end of the call is going omg turn down your mic, you're too loud etc etc.
Pretty much every post I've come across online about this issue says, Un-check the box, which I've done. They also say to remove exclusive mode/give application priority in the microphone properties, which I've also done.
It's still doing it however, and I'm wondering if there's something more to this. My friends PC also does this, and would like to be able to give him a fix. It's quite annoying when you're playing Civilization 5, and might be listening to music, and Skype automatically adjusts the volume to stupidly loud levels to catch that background noise.
Has anyone else ever run into this issue, and if so, do you know any fixes aside from the ones I, and many others have tried? I'd be asking on the Skype community forums, but no one seems to know an actual fix for this.
I've been searching in Google for over 2 hours now trying to find a suggestion that's not 'remove exclusive mode' or 'un-check the box' because neither is working. I've even gone into the shared.xml to edit the HTML settings, but it all looks perfectly fine when I do, no need to edit.. Something else is causing this issue.
