okay now let's start in small steps. First go to your BIOS. Keep EVERYTHING on AUTO EXCEPT the following, which we will change manually-
(i) CPU Voltage= Fixed Mode (set at 1.2V)
(ii) CPU Load Line Calibration- Level 1
(iii) CPU Ratio- All Cores and change the Value to 40 from 33.
Then save the options and exit the BIOS.
When Windows opens, do a 10 minutes run of Prime95 on Blend Mode, keeping HWMonitor open. Watch down the maximum temps (max is 80C). If it's stable, then go back to BIOS and increase your multiplier by 1 notch and run Prime95 for 10 mins again. Repeat this step until Prime95 fails. When Prime95 fails, then report back here.
