@twst. GA-970A-DS3P, the P after the DS3 is supposed to mean that the board now has digital VRM circuit and also has some form of a heat sink on the VRM mosfets. The "P" version of that mobo is in Rev 1.0 since it is supposed to be a newer model. However in Giga description on the website, I see nothing about the board now being 4 +1 digital VRM. Like I said some of the other boards with the added "P" at end of model have specifically stated the board now had digital VRM.
Now I doubt anyone has acted more in keeping with the "mobo police" than I have with these boards that are generally n0t robust enough to handle *whatever* type overclock some of us get out of out FX processors. And it is very true that the board and cooling will be the first limit to the overclock you can get from an FX processor. Why?
Well your FX-6300 has a base clock speed of 3500Mhz an itermediate clock speed of 3800Mhz and then a full on clock speed of 4100Mhz with ONLY the use of half the cores. Now left in a stock condition the cpu and mobo work together to keep power drawn thru the board to a reasonable level.
Now comes the rub. Normally when we overclock, we have to turn off TurboCore that would boost your clock speed to 4.1Ghz but with only on half the cores and not all of them. We disable TurboCore to GAIN control of the multiplier and then ALL cores come into play or begin to work. Now we don't have the cpu and the mobo working together to keep power drawn thru the VRM circuits to a reasonable level according to the mobo maker.
All the cores on ALL the time is an immediate increase in power drawn thru the VRMs. Some boards (don't have yours nor plan to) still have some control over the power draw thru the VRMs even with TurboCore off and can sense too much current thru the VRMs and will reduce the cpu multiplier and slow the cpu and thus try to save the board. You will see users asking about "throttling" under load and that is what that is. So you clock up some with TurboCore off and ALL cores on and suddenly the mobo may throttle your cpu speed anyway. So much for a good overclock.
Now back into mobo police mode. None of us can tell you that you cannot overclock the newer DS3P mobo. We give advice based on how hot and how much power we have experienced with out own overclocked FX processors.
Sure I can take even an 8 core FX processor and overclock it into the Mid 5.0Ghz range and even run P95 Blend for over 2 hours. I have the very best Asus mobo I could buy and water cooling that cost in the $285.00 range. Not a problem.
If I were you now that you know some of the why we make suggestion as we do, you might try and disable TurboCore and set the cpu multiplier to 19 which would giive you 3.8Ghz cpu speed but with ALL cores on. This may feel more powerful. It should be with ALL the cores in use. You would need to make sure that using HWMonitor "free" from CPUID com that the cpu temp, whatever your Giga board calls it does not exceed 70c and the Core/Package temp does not exceed 62c.
IF the two temps BOTH stayed way below their suggested maxes at 3.8Ghz when subjected to at least 20 mins of P95 running in BLEND mode, then you might try a multiplier of 19.5 for just a hair more speed. Again you better monitor those temps. In my minds eye the BIG overclocks we are used to seeing and doing are out of the realm of doable for you. But you might and should gain at least some extra oomph from all the cpu cores on and not exceeding 4.0Ghz.
Again for clarity, when we overclock FX processor we disable TurboCore to gain multiplier control and this is what turns on all the Cores and shoots the power required thru the roof and brings on the heat all of which can have a less than positive effect on our parts.
RGone...
