Purchased a second 4p system. I will need to keep some of that hot air out of the small room these will be in.
Take a 20 inch box fan and place or the floor in the doorway blowing cool air in the room, keep door open.
May just water cool both 4p.
Lol Hardass...... You always seem to have something on the go.
Consider Yourself on Notice, if you do this we want pics!!
I am in South Florida, box fan not gonna cut it. It is already really warm in room now with a single 4P system and my reg system running 2 watercooled 7970s.
And it isn't even summer yet. Will be way to hot in there once I add another 4p system. It has to be watercooled. May just water cool both 4p.
Unless the water cooling deposits the heat somewhere outside the room, it won't matter if its water cooled or not. The heat will still be in the room, all be it, moved from the CPU to somewhere else.
I don't think Florida is made for summer folding on a p4. Now if you waltz on up to Canada, we will show the meaning of COLD.
And I'm in Texas and I have 4 PC's in 1 room, the 4P being 1 of them.
Well, if you use long hoses and mount the radiator outside a window, that would definitely remove heat from the room.
So what size room and how do you cool the room? I am in a apt not a house. Room is 8x10 have central air but cannot set to 65 everyday just to cool 1 room. Have a box fan in widow exhausting hot air to outside, fan in hallway blowing cooler air into room.
* My Thinking * Watercooled I have 1 Rad and 3 fans instead of 4 HSF blowing hot air into room. I know when you take a cpu on air and switch to water it cuts heat going into room. Same with vid cards.
Check out the DC forum over at [H], Patriot amongst others watercooled his 4p rig, he managed to get his ES chips to 3.4ghz, from 1.9.
I think he used EK blocks but I could be wrong, then you just need a large enough case
http://www.ekwb.com/shop/ek-supremacy-amd-c32-g34-acetal.html
$76.53 a block, so $306 for a set of 4.
