I'm assuming you used a bridge, correct?
What version is your driver?
I might be off, but do the discard and apply buttons become selectable if you choose disable AMD crossfire??
Yes it is selectable for disable crossfired but not enable
I am not at home at the movement. I guess; I;ll try it and keep trying to getthe damn thing to work.
