Hi ,
As you can see from my signature I have been using I7-920 CO for some time.
I managed to buy a I7-960 and installed it last night..Had to remove mobo to get better connection for heatsink. Everything is up and running. All settings on auto for now. Ran Prime95 with Realtemp for 15 + minutes to check. Max temp was 45 deg.
Everything is running well. My problem is the blue lights at very front outsiide top of case. The lower one below power light now also stays solid. Befoe it would flash and fluctuate as you were changing programs or downloading.
Seems like something simple, I even checked connections to F panel on mobo. Obviously I want to try solve this before I move further.
I am not used to the extra power of the 960 and maybe its something else.
Many thanks Hope you can help.
Texasboy
Texasboy
