Hello everyone,
This is my first overclock ever so I would love some help with it.
My specs:
Asrock P67 Pro3
I5-2500K with Noctua DH-15 Cooler
8GB Kingston 1333Mhz
MSI GTX970
PSU: Corsair TX650.
I know this isn't top of the line but I don't see a reason to change my CPU just yet.
I would like to have it overclocked to 4.5GHz if possible.
Below are my settings in Bios with three changes: Internal PLL is DISABLED and Additional Turbo Voltage is at minimum – 0.004V, Offset is set to -0.055V and not -0.045 as in the screenshot. With offset set to -0.060V the computer is bootlooping.
With settings as above I went for Intel Burn Test – Stress level: Maximum and 10 passes. It passed without any errors and my temps at the end (after 30 minutes) were: 63 / 68 / 70 / 66.
CPUID HWMonitor was reporting CPU Vcore max as: 1.336V. Do you think it is too high and I should drop CPU Ratio and try to lower voltage more?
Any help would be greatly appreciated. And I’m sorry if my English isn’t perfect (not my native language).
My specs:
Asrock P67 Pro3
MSI GTX970
PSU: Corsair TX650.
