Pretty Humid and Sub ambient for a daily driver is going to be tough to do. When benching especially with only cold water, the condensation can get pretty bad. When I bench with cold water I always do a tear down after I'm done and let the board dry for a few days before starting it back up. Even with insulation if some water gets under or around it, you may have some big issues. Do you really need to be running 5.0 daily?Ambient in my home is usually 76F (25C) and South Carolina is pretty humid. I only plan on cooling down to 60F (15C). I may go cooler just because I'm a tinkerer. The idea is to get rid of the noise of the 8 fans in the system by putting an A/C unit in the attic and remove the computer heat up there. If I can drop voltage and gain or maintain my current clock speed I'll be pleased.
John
I was thinking cost of AC unit mostly plus the power to run it with the pc. The pump system I am imagining a pond pump may be needed to send it through such long distances with adequete flow rates?
I'm curious the runs you need with tubing? You thinking wall fish it up to the attic? How long is the run? I assumed the attic is finished and getting central air already?
Sorry for the 20 questions, this intrigues the heck out of me.
Edit: sorry, im a bit off topic...ill,look for your build thread.
Just out of curiosity have you thought of doing a geothermal loop and forgo the whole A/C in the attic.
