- Thread Starter
- #81
My advice, for someone that probably isn't as computer savvy, go Intel.
If it was yours or mine, I would say go for it, but for someone else give it some thought.
The FX CPU's are great, but sometimes they really need some tweaking.
You're right, the Geforce Experience software has a built in capture software.
This is the only software (that I'm aware of) that takes advantage of this encoder.
Ok so what do I get my brother then that's comparable to this FX build on the intel side?
In a bit I will be listing where the wife's build is at..........
