Your Southbridge is heatsinked. Clearly that's going to get pretty warm without adequate air flow. I would think you audio chips might as well but it's not an issue on standard cases. It might be in yours.
Are there vent holes on the top of the case? If so you may be fine.
Just make sure you don't "connect" things behind the GPU's PCB and on the MB. Otherwise, you should be ok unless the GPU and SB temps say otherwise. It's possible, some heat might get transferred from the hotter GPU to the SB.
Maybe you could try a different mod with something like this or this and the likes.
All these extra water blocks for want of a $15 Noctua low speed fan.....
Here's another thought for consideration Tobcar, I'm assuming you're planning on using 3/8 tubing due to the very small form factor. With as many blocks as you have and your (assumed) small tubing you may have a low flow rate which can hinder your temps. I'm not trying to discourage you. This seems an interesting concept and I would like to see it pulled off. You may want to consider 2 pumps in to loop to aid with flow.
Two pumps in series
Quick question, a little off topic, but why do we need to cool these M.2 drives? I have 4 of them in my laptop with zero issues with heat. So this is kind of intriguing to me.
I really don't think it will make a difference as it will always be a push pull. I think the whole premise of dual pumps is just to keep the pressure high enough to keep the flow rate up.
Indeed it does have fans. But only directly over the CPU and GPU. The middle of the board (where the 4 M.2 are located, stacked on top of each other even) has no fan for airflow. Just intrigued me is all.Normally, the problem is just thermal throttling during heavy use; in a case with good airflow, a small heatsink is usually enough to counter this.
In a crammed passive case with almost no airflow, some type of cooling is needed - not just to avoid throttling, but also to make sure the drive doesn't go bad from constant overheating.
Laptop's do have fans - they typically spin up only when needed.
Mine are 80mm 128gb drives from mydigitalssd. I have not monitored operating temps because it doesn't get hot enough for me to worry. Laptop is an MSI GT72 Dominator ProWell, what type of M.2:s are you running? And do you know your operating temps? Thermal throttling only restricts performance of the drive during heavy use at high temps, so unless you both use disks heavily and measure throughput, you might not experience / notice it. What laptop is this?
