I'm doing a External Watercooling build in an FC10 Alpha case. PSU (Seasonic Ti 750) is also external, so there will be almost zero airflow in a very small case, fitting snugly around an ASUS ROG Hero IX and an MSI GTX 1080 Gaming X (tilted vertical, on a flex riser card). This means that I need to cool my 960 PRO by other means that just sticking a small heatsink on it and the obvious option is to include it in the loop.
Chip dimensions on the 960 PRO are around 71x17mm, water block surface can be slightly larger, but not by much or I will have problem fitting it.
Anybody know of a water block around this size that I could stick on the 960 PRO?
RAM blocks are too big because RAM-modules are about 133mm and most other blocks I've see are also just too big.
Any ideas?
Any ideas?
