SkaGoatMaster said:
I say use one that u like the best, you should like it's feel, and weight and what not.
I completely agree. Go to Best Buy or Circuit City or wherever, and play around with both cameras. See which one you like the feel of best, and make a decision based on that. The cameras prices reflect their individual attributes, which in all but several cases, are identical.
The Fuji feels like a studio camera, it's a 2-hander for sure. It takes 4 AA's, and can be a power hog if you use the LCD at full brightness for long periods of time. But you can turn the brightness down, or use the EFD instead (BTW, the EFD is completely enclosed, so you can use the camera in the brightest situations without any glare on the EFD. This also has the advantage of a true reticule, instead of an optical reticule, which is never dead on because it and the camera lens cannot occupy the same space). The minimum macro distance is 2.5" so you can get right up close to those cores.
The Canon takes 2 AA's, and isn't quite as heavy. I believe it's minimum macro distance is 5", but don't quote me on that.
The Fuji may appear bulky, but it is quite small, it's just square. This is to accomodate the zoom lens protrusion. The Canon is traditionally rectangular, which is a godsend if you're looking for a case (I STILL havn't found a case worth buying for my Fuji, and I've had the camera for 3 months).
So basically, if you need the Zoom, and can put up with the sometimes awkward shape of the Fuji, and want a close macro, then get the Fuji. If you want a large selection in camera cases, and a traditional easily holdable chassis, get the Canon. Heck, you could even base your decision on the shade of silver you like best, Canon or Fuji. =)
