- Jan 10, 2004
- Sou Cal
Hello,
I am looking for a 19" LCD monitor. I am going to use this LCD monitor mostly for Graphic Design work rather than gaming and my budget is around $200-250. It must have a DVI connector because my current CRT monitor is occupying the VGA port. This is LCD monitor is going to be in a Dual Monitor set-up with a CRT Monitor. So far, this is what I found:
1. BenQ FP93G
(http://www.newegg.com/Product/Product.asp?Item=N82E16824014117)
2. Wise Wing W902DB
(http://www.newegg.com/Product/Product.asp?Item=N82E16824104001)
3. Tyris T901DB
(http://www.newegg.com/Product/Product.asp?Item=N82E16824224008)
4. Rosewill R912E
(http://www.newegg.com/Product/Product.asp?Item=N82E16824021019)
All of these LCD monitors are affordable, but I am currently leaning towards the BenQ FP93G because it's contrast ratio is much higher compare to the rest. Which LCD Monitor do you perfer for Graphic Design work? and why? Please let me know and help me narrow down my choices. Thanks.
1. BenQ FP93G
2. Wise Wing W902DB
3. Tyris T901DB
4. Rosewill R912E
