- Dec 9, 2003
- Orlando, FL
I set my CPU multiplier to 8x in BIOS and according to CPU-Z it's changed back to 6x when I get into windows... Is there anyway I can fix this?
It is Intels speedstep. Go in BIOS - disable C1E and EIST.
It is Intels speedstep. Go in BIOS - disable C1E and EIST . I recommend leaving it enabled. This way your CPU is not running @ full clock speed when it is not needed ( creating less heat and saving energy).
thank you, i couldnt remember the EIST one....
but causes headaches if your trying to overclock, so if overclocking, disable
