HI all
I am having problems with my new setup. Just added to my system MSI r9 290.
The cards gpu usage spikes in every game from 100 to even 0 and so on its just acting crazy.
Temps are great for everything 45 degrees for cpu and 70 max for gpu
Tried both drivers latest beta and whql with clean install using ddu in safe mode
Tried oc my cpu no luck spikes ar there.
Can it be my psu ? If that how to tell its psu fault ?
Can it be fx 8350 bottleneck for that card ?
AMD FX 8350 stock speeds hyper evo 212 with to 120mm fans push and pull
MSI gaming r9 290 twin frozr 4
asus sabertooth 990fx r2.0
8 gigs 1600 mhz ram
650 w OCZ plus bronze zs series
case with a 4x 120mm fans for air movement
8 gigs 1600 mhz ram
