TL;DR: When my CPU was locked in its socket, the thermal paste bonded the heatsink so tightly that when I tried to remove the heatsink, the CPU came with it. Thankfully there were no bent pins, but now I have to do it again and I'm afraid it's going to be ripped out of its socket again and I won't be so lucky. Is there a safer way to remove a heatsink without pulling the CPU against its socket? The socket locking bar is obstructed by the heatsink, so lifting that to remedy the situation is not an option. It's an AMD FM2+ socket.
Long version:
This problem focuses mostly on the thermal paste so I decided to put it in the cooling forum; if it's in the wrong forum, my apologies.
Alright so I'm building a desktop, I am confident my parts work (like a moron), put it all together and the video won't display on the monitor. So going through an available checklist I found on Google, one of the things was I might have installed my CPU on a socket with a covering on it. I attempt to slowly, carefully remove the heatsink from the cpu, which is bonded by thick thermal paste, and when I finally get it loose, the CPU came with it.. The CPU that was locked in place by the socket was torn lose.. I check the pins with extreme scrutiny, which should be bent considering the situation, and they're fine.
So I put it back together after determining I installed everything correctly the first time, and same problem (no video); I determine the motherboard is bad because while a case speaker is plugged in, when the computer is turned on the motherboard won't beep. They usually make a short beep when successfully booted up, or long beeps when certain parts are missing (like RAM), so even with RAM missing, the motherboard isn't beeping. I've tried two separate case speakers, so I have to conclude I have a bad motherboard and need to RMA it.
Except now I have to remove the heatsink/CPU again, and don't want to rip out the CPU that's locked in its socket again. The locking bar is obstructed by the heatsink, so I can't lift that up. It's an AMD FM2+ socket.
Long version:
