A as1248 Registered Joined Nov 29, 2009 Jan 4, 2010 #1 What is the diffrence between these two PSU from corsair? 1-Corsair CMPSU-650HX 650w HX Series 80 Plus Bronze Certified Power Supply 2-Corsair CMPSU-650TX 650-Watt TX Series 80 Plus Certified Power Supply compatible with Intel Core i7 and Core i5
ThePerfectCore Red Raccoon Dojo Joined Mar 1, 2002 Location Texas Jan 4, 2010 #2 The stickers are different colors. As, newegg says the HX has: 1 x Main connector (20+4Pin) 1 x 8-Pin EPS/ATX12V 8 x Peripheral 9 x SATA 2 x Floppy 4 x PCI-E Click to expand... whereas the TX has: 1 x Main connector (20+4Pin) 1 x 12V(4/8Pin) 8 x peripheral 8 x SATA 2 x Floppy 2 x PCI-E Click to expand... In addition, the TX is advertised as being "Crossfire ready".
EarthDog Gulper Nozzle Co-Owner Joined Dec 15, 2008 Location Buckeyes! Jan 4, 2010 #3 Ehh, the biggest difference is MODULAR(HX) vs. NON MODULAR (TX).
Xtreme Barton Member Joined Jan 17, 2004 Jan 4, 2010 #4 650HX seems to pass the higher efficiency rating also
burebista Member Joined Mar 13, 2006 Location Romania Jan 4, 2010 #5 And two different Seasonic platforms S12II (TX650) vs. M12 (HX650). I'd take HX650.
fire2havoc Member Joined Nov 15, 2009 Location California Jan 7, 2010 #6 The HX is modular whereas the TX is not. Also, the HX is a newer power supply and has a higher efficiency.
