- Apr 7, 2012
- Near Toledo, OH
I have been using samba from my main server for many months now without a problem. But I moved and let the fun begin..
My network is currently as follows:
Cable modem -> Wireless Router -> Switch box -> Server/other PC's
.....................................................-> The odroid machine (with samba problems)
The odroid machine with has the samba connection issues can see all of the network locations but has permissions issues. I enter my name/password and it tells me to re-enter it over and over. These issues occur with XBMC and with the native file browsing w/ gui. This odroid runs Debian 7.6 as well as my Server does too.
This computer worked before, I believe with:
Cable modem -> Switch box -> Server/other PC's
..............................................-> Router-> The odroid machine (with samba problems)
But it stopped working at one point which lead me to change the config.
(Notes)
1. I have connected the odroid machine directly to the switch which also contains the server - so it is not an issue with my router.
2. I have replaced my original modem that acted like a modem/wireless router/switch with just a standalone version, problem persists.
3. I have restarted every machine on this network..
4. Every other wireless/wired computer on the network works without problem connecting to the share (with the same user/pass)
5. I have reinstalled the ROM that is running on the odroid device -> I have tried before running "apt-get update" and after.
6. You have to remember I was connected fine for 12 hours while I watched shows. When I went to use it the next day is when I had problems..? (all variables were kept same then).
7. I am able to connect to the share via FTP but most files are too large to be transmitted for streaming purposes..
I will keep working on this, but am looking for any possible help if you have any ideas. Thanks
(Notes)
