- Jan 9, 2006
So I have a gigabyte ex58-ud3r motherboard. It dawned on me I could clean up the inside of my case and quiet it down some when it's not being stressed. I removed all of the big clunky molex connectors and splitters and hooked my case fans 3 pin connectors directly to the motherboard system fan headers. No need to run full blast at idle I think. I have 2 front and one top 140mm fans (thermalright 900rpm) and one rear 120mm (also thermalright 900rpm) set up like so...
2 front 140mm fans - Hooked to a 3 pin y cable splitter and plugged into sys fan 1
1 top 140mm fan - plugged straight into sys fan 2 (4 pin input compatible with 3 pin fan with offset tab)
1 rear 120mm fan - Plugged straight into sys fan 3
The problem is the front 140mm's are running at full speed despite having a third wire for sensing rpm, and the rear fan along with sys fan 3 don't exist according to the bios and gigabyte easy tune. Despite not showing up in bios the rear fan is definitely on and spinning slower than it was before but I wish I could see the rpm. The only one working like it should (for sure) is the roof fan plugged into 3 of the 4 pins on sys fan 2. I used hwmonitor with prime95/furmark to make sure the speed was climbing with the heat. I also tried the top fan with sys fan 1 to make sure it was the header and it also ran only at full speed so it's not a certain fan or y cable. What am I doing wrong? I don't see anything else in the bios that would let me take more control of the system fans. Help please. Thanks!
