My cousin has old computer 10 years back. Computer is assembled i.e. made up of different different parts from different brands.
Computer was working good since last 9 years. It is no more working since last 1 year. My cousin called up some hardware guys/experts in the city/locality. All of them may have tried their best to start computer; but they failed ultimately & some of them suggested to replace X(may be motherboard=mobo),while other suggested to replace item Y(may be RAM). But we are not sure where is exact fault? This excercise is only for identifying which parts are damaged. (so that we can replace them & make computer functional again)
So my cousin handed over computer to me. Actually monitor was CRT hence bulky, i only took CPU cabinet(fitted with 1 switch for power on & another for reset & LED & small speaker) +keyboard+mouse+motherboard(processor/CPU fitted)+cables+hard disk+ram+PSU(SMPS) from my cousin's home. PC doesnt have any graphics card/other addon cards/games cards.
Brief Specifications are as under
1. ASUS motherboard K8V-MX
2. CPU AMD Athlon-64
If you need any other detail, please let me know.
Tools i have
1. Multimeter
2. LEDs & resistors (if required for any kind of testing)
All parts are isolated(except CPU) when i received from my cousin.
As i was not aware about any hardware/hoook up etc..i try to google/help from other chat forums what should be the correct method/flow chart to fix/troubleshoot the computer hardware issue.
I found few articles & also got some help from online friends basis that i tested as under till now.
1. Overview/visual checking of all major parts like PSU, mobo, RAM, terminals/pins etc.. all found ok. Capacitors are also intact.
2. Tested PSU indenpendently using paperclip method & result found satisfactory. PSU fan started. (when Green & black wire are sorted)
3. Checked CPU cabinet speaker resistance; multimeter shows 0.02 ohms
4. Setup: PSU connected to mobo ( via 2 cables: 20 pins & 4 pins). CPU speaker connected to mobo(2 pin thin cable). & removed all other components (RAM specifically) from live circuit as other components(DVD Drive/Hard disk ) were already isolated .Then switched on Mains power supply.
Result:No beep/sound & Yellow LED on mobo working/ON.
I guess there may be problem with speaker or mobo or CPU.
Can anyone suggest me what should i test next & in which sequence ? (request to elaborate as i am not much familiar with technical/computer related jargons/terms)
One of my friend suggested me to clear CMOS. So that is my next check point/target/focus as of now.
Please suggest your ideas; Thanks in advance
Keyboard/Mouse/Monitor has not any problem.
What i want to avoid (if possible) swapping mobo/CPU during testing as i may not able to find any equivalent parts(working mobo/cpu) from my region/locality.
Tools i have
1. Multimeter
