Hey, im a beginner, never done this before, so I need to know if one 240mm rad is enough to water cool a 4770k probably going to be around 4.5-4.7ghz at 1.215v-how ever many volts it takes to get higher, and a gtx 770, I havent really tested the cpu too much yet bc I onlt have a hyper 212 evo, I just put this system together (it was my first ever build) so im new to all of this: overclocking, water cooling, etc. I actually just tested my cpu just to test its potential, I got 4.4 at 1.21v I didnt even really fine tune, I couldve probably used less volts but yea. I dont want to do any more oc'ing till I get a water cooling set up.
And how much difference would it make in actual degrees between a closed loop cooler, (a good one, like the 240l GLACER thats supposed to be similar to a h220 "on steroids") and a custom water loop with good quality parts?
So my question is if I was to do a clc or a custom loop would I need more than 1 rad to cool both the cpu and gpu? This case can fit only like 3 rads (2 240s and 1 120) but it wouldnt be optimal to have 3. I would like to just have 1 240 as a top exhaust, and maybe 1 120 as a back exhaust if I can fit it.
Also I am going to de-lid so I'll be using coollaboratory's liquid ultra, would anyone recommend this on top of the IHS as well? And I read that the gpu gets too hot for that TIM so what other normal paste would you guys recommend? Is tuniq mx-4 the best? I don't care about price I just want the best cooling period.
Sorry for the long *** thread lol
