How much is a stick of TwinMOS 512MB 3200.
I cannot find in any review or product spec about the TwinMOS timing specification. For Corsair, at least I am sure I'll be getting 200 MHz 6-2-2-2 timing @ 2.5V for a 3200LL, or 217 MHz 6-3-3-2 @ 2.5V for a 3500C2, otherwise I can ask for RMA from Corsair. Whether I can get 10% more from it is a matter of "luck", most ppl on the forum say Corsair can oc by 5-10% (but this is extra and no guarantee).
I also find many reviews about memory, some how the sticks they tested, for some reasons, can go much higher than spec. I once got an OCZ EL 3500 based on reviews saying it can go as high as 240+ MHz, but mine can only go to 210 Mhz (which is below spec).
My concern about buying TwinMOS is that the spec on timing is not clear. It says it can go up to 200 MHz, would it be Cas2, or Cas2.5, at x-2-2-2 or x-3-3-2.5, it is not clear to me. If I can only run at 200 Mhz and crashes at 201, even at relax timing, I am out of luck, and I cannot complain without a clear timing spec.
Same thing, I hesitate to order Kingston HyperX 3500 which spec at 8-4-4-2, I cannot complain if it can only run at 217 MHz with 8-4-4-2. I would get Corsair 3500C2, since I know at least I'll get 217 MHz at 6-3-3-2. Also 8-4-4-2 may be an indication that the memory may not be able to oc much higher than spec.
