- Dec 24, 2001
first let me say this is being done on a laptop so things that apply to desktop systems may not apply here.so testing and such will seem odd.
fans change speed at set temp points and that scews max temps.
this is being done on a dell i6000 with a 735 dothan thats been pinmodded too 2.26ghz and overvolted too 1.388v its small but was necessary for stability.
i had been useing radio shack white grease due to running out of as5
temps would max at 62c with fans on high and were set to kick in at 55c
this was a little too high for my liking.
i made a thread shortly after asking what i could try besides as5 as ive always used it but im always adventerous.
i was advised to try Shin Etsu X23-7783D that can be found here:http://forums.pcper.com/showthread.php?t=325489
ill also add dealing with GBR was a pleasant experiance.
i also read his guide on how to apply this stuff since its much thicker than as5.i used a heating pad set on high for about 10 minutes to make it spread easier.i then used the tape method to get an even thin layer.
as i said before my temps with teh RS silicone were 62c max with fans tripped to high at 55c
now my temps after this application are 52c,thats a 10c drop!
i am also told this stuff has a cure time of about the same as5 and temp drops will be even more dramtic than as5 after the cure.
ill be running prime95 for several hours at a time and shut it off for a cool down.this will cycle the cureing and hopefully make the cure time shorter.
i cant comment on idle temps yet,mine is set to max perfomance 2.26ghz while on ac.but i will test it when set to max battery wich is 800mhz .74v soon.
ty for everyone help in finding this serynge of gold
