Yes, the valves would help (been there myself) but also can restrict flow. Another good speed tip is if you can get a big enough res 'above the pump' to hold more than the system's capacity. That way it can just start pushing in the water and you don't have to add any. By 'big' I mean like this one that is over half a gallon ~liter.got all fingers working, just can't get the 1 wet for a week or 2.
if ball valves didn't cost like 7-8 per valve i would have sodlered 2 valves on each side of the shut off's to make it easier to take apart and so i wouldn't have to drain it all.
Any fitting will reduce flow compared to the same length of tubing, but you can reduce the losses by sizing the fitting a little larger.i would only use ball valves if i did use them as they don't really reduce flow. i can get gate valves which would be the next best thing, for a couple bucks less, but i would just go with ball vales for the ease of shutting and turning off.
