Krowa 02 said:I dont see this thing at newegg
Under AMD A64 mobile processor section.
It has A64 mobile 2800+, 3000+, 3200+. All 1MB L2, rated 1.4 V.
I don't overclock at all from the BIOS. I use a config script at boot to overclock within Windows. But the 3200+ mobile would probably still have the best chance for a high overclock.hitechjb1 said:
Under the scenario that the BIOS FSB setting is not high enough (say 300+ MHz) to max out the CPU with a max multiplier of x8, ....
If Clockgen is used to set higher FSB setting, does that mean that after every reboot one would have to get into Clockgen to readjust the CPU frequency, .....
If so, motherboard with higher BIOS FSB setting (300+) or a CPU with 9x multiplier is preferred, not using Clockgen.
9x CPU is not much higher in price than 8x ones, potentially higher chance of overclocking, as price and yield mature, higher multiplier CPU will be more affectable.
Gautam said:The DTR complicates my setup. Hopefully the newer boards won't suffer from this(I think that the Shuttle already doesn't), but I cannot overclock from the BIOS. Even at a 201MHz HTT, it fails to POST. It will only boot up at stock speeds. I can manipulate timings, dividers and voltages which suffices to do whatever I need. People first adopted ClockGen over BIOS overclocking in normal A64 setups to avoid BIOS corruption that sometimes accompanied HTT's above 270. I don't have hard evidence of this happening; it's just what I've heard. For Linux, there is no alternative that I know of unfortunately. I'm only keeping my memory at 210, and for notorious BH5, there's not much doubt that its stable, but if I were to go higher, not being able to run Memtest could cause problems.
So, optimally, using only the BIOS would be preferable. Clockgen also seems to have problems with changing the multiplier. It hangs often. It seems like changing the multiplier only works reliably when the HTT is at 200mhz. With that said, you way want to opt for the 3000+; 9x300 should give you plenty of headroom.
yazz88 said:how about the 35w mobile a64?
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-448&depa=0
Actually your mem should run 5:4, just a little volts and decent timingskulki said:well I got 1Gb of PC3200 memory with me. I really cannot afford to buy additional memory say PC4000. Now having said that, would it make sense for me to buy this mobile A64 chip. It seems that only way to OC this processor is by increasing the FSB to around 300MHz. I am sure my memory wont run 1:1. Even a 5:4 wont work with PC3200. What possible ratio's can I set so that I can use my PC3200 and still get FSB to 300?
thanks
