12.90 Drivers get better 3Dmark 2001 scores !
Geobronc
I am getting about 600 more points with the 12.90 drivers versus 12.40. I think Nvidia is on the right track !
I get 6144 on mine. Have you thought about lowering the multiplier to 10.5 and running a higher FSB? This will get an even better score for you.
OMG they are some seriously high scores! I haven't even heard of >6k scores on 3DMk2k1 !
Well done people, I have a system quite like urs and I only get 5000 marks at default. Im confused. It must be the extra 200-300Mhz faster processor.
I just wish I could see the benchmarks on that Kryotek GF3 I saw the other day clocked to a whopping 300Mhz Core and an even more amazing 600Mhz RAM speed w/o artifacting. They were using the best A5 stepping and the best 3.8ns Elite RAM though.
Damn, just the thought of a GF3 hitting those speeds makes me chill :)
I see threee reasons why we can get to 6000 + scores and your at 5000.
1. We have the extra mhz (300-400 more).
2. We are overclocking our Vid cards higher (235/550 vs 200/500)
3. The new 12.90 Drivers are getting me more than 600 points higher then 12.40.
I have seen some people in the 8000-10000 point range with 3dMark 2001.
They have P4's running at over 2ghz though and Geforce 3 's too.
I don't know what I'm doing wrong but I only get about 3900. Anyone have any tips for me to make my rig faster. My card won't let me tweak my memory clock over 458MHZ, but the graphics clock I can, If I turn up the memory clock my screen goes crazy. Here are my scores.
Project Name My Benchmark
Operating System Microsoft Windows ME
DirectX Version 8.00
Mobo Manufacturer ASUSTeK Computer INC.
Mobo Model <A7M266>
CPU AMD Athlon(tm) Processor 1260 Mhz
FSB 140 MHz
3D Accelerator WinFast GeForce2-GTS/Pro/Ultra Display Adapter
Graphics Chipset NVIDIA GeForce2 Ultra
Driver Version 4.12.01.0648
Video Memory 64 MB
Resolution 1024x768 32bit
Texture Format Compressed
FSAA Disabled
Z-Buffer Depth 24bit
Frame Buffer Double
Rendering Pipeline D3D Hardware T&L
3DMark Result 3908 3D marks
Game 1 Car Chase - Low Detail 76.2 FPS
Game 1 Car Chase - High Detail 29.0 FPS
Game 2 Dragothic - Low Detail 57.5 FPS
Game 2 Dragothic - High Detail 20.3 FPS
Game 3 Lobby - Low Detail 78.4 FPS
Game 3 Lobby - High Detail 40.1 FPS
Game 4 Nature N/A FPS
Fill Rate (Single-Texturing) 381.1 MTexels/s
Fill Rate (Multi-Texturing) 719.8 MTexels/s
High Polygon Count (1 light) 15.4 MTriangles/s
High Polygon Count (8 lights) 3.7 MTriangles/s
Environment Bump Mapping N/A FPS
DOT3 Bump Mapping 57.6 FPS
Vertex Shader Speed 45.5 FPS
Pixel Shader Speed N/A FPS
Point Sprite Speed 1.1 MSprites/s
hmmmm, That seems pretty low for a Geforce2 Ultra.
You may have a defective Vid card if the Memory wont go higher then that.
I hear most Geforce 2 Ultra have 4ns memory and some have 3.8ns memory and should be able to hit 500mhz.
Which drivers are you using?
I have found that the 12.90 beta's give me the best frame rates and benchmark scores.
Also are you using the Nvidia overclock utility built into the drivers using coolbits registry hack? Or are you using the utilities that came with the card for overclocking?
You are better off using the Nvidia Drivers overclock tool with Coolbits hack,
IMHO at least.
Geobronc (Jun 29, 2001 04:49 p.m.):
IMHO at least.
I just figured it out! You have the 6.48 Drivers! No wonder!
Go get the Nvidia 12.90 Drivers from here......
thanks I'm downloading now, and I was using the utility that came with the card.
Do you have the coolbits hack to enable the overclock tab in the Nvidia Geforce setting tab? if not.. get it here...
I would also uninstall your cards stock utilities and drivers before you loead the 12.90's.
1. Change you drivers to Standard VGA.
2. uninstall stock drivers and utility.
3. install new 12.90 drivers.
4. Double click on Coolbits reg hack to load it, then go to Nvidia Geforce tab, additional properties, Overclock tab should be there. You will need to test new settings then hit apply.
That should do ya!
Dude I have a question, I did everything you said and the coolbits don't work. Where the hell does it say what drivers your using? I only see 4.12 or something and the coolbits is in my reg because a checked with regedit but I don't get the extra tab. HELP
This is my score with the new drivers, but I still don't have coolbits.
Mobo Model <A7M266>
FSB 140 MHz
3D Accelerator NVIDIA GeForce2 Ultra
Driver Version 4.13.01.1290
Video Memory 64 MB
FSAA Disabled
Frame Buffer Double
3DMark Result 4249 3D marks
Game 1 Car Chase - Low Detail 76.7 FPS
Game 1 Car Chase - High Detail 29.9 FPS
Game 2 Dragothic - Low Detail 68.3 FPS
Game 2 Dragothic - High Detail 27.4 FPS
Game 3 Lobby - Low Detail 82.1 FPS
Game 3 Lobby - High Detail 41.6 FPS
Fill Rate (Single-Texturing) 365.1 MTexels/s
Fill Rate (Multi-Texturing) 693.1 MTexels/s
High Polygon Count (1 light) 19.5 MTriangles/s
DOT3 Bump Mapping 56.1 FPS
Vertex Shader Speed 45.1 FPS
Point Sprite Speed 9.5 MSprites/s
Published No
Craig,
Were you able to get the Coolbits reg edit working to enable overclocking?
If so, did that help with your overclocking the memory higher?
And what score after overclocking do you get?
I'm using the new drivers and overclocked the card's core/memory to 300/500 and these are my scores, seems low for a 1200mhz and a ultra card.
Mobo Model <A7M266>
FSB 140 MHz
Video Memory 64 MB
FSAA Disabled
Frame Buffer Double
3DMark Result 4521 3D marks
Game 1 Car Chase - Low Detail 85.0 FPS
Game 1 Car Chase - High Detail 30.8 FPS
Game 2 Dragothic - Low Detail 74.2 FPS
Game 2 Dragothic - High Detail 29.6 FPS
Game 3 Lobby - Low Detail 86.6 FPS
Game 3 Lobby - High Detail 42.7 FPS
And I have another dumb question can I keep my card at these Frec. or will they make it to hot and fry my card? I've got good case cooling CPU runs about 42C at idle.
Craig,
That score is very Good actually for a Gf2 Ultra.
You can run your card that high, shouldnt be a problem. If you get lock-ups or visual problems, then back the Core and Memory down by increments of 5.
Well, see! You went from 3900 to 4500+ !! Thats a 600 point increase! Not bad!
Also, Remember that the ONLY reason my score is so high is because I have a Geforce 3 (235/550) and I have a little faster CPU (1466mhz).
