- Nov 21, 2005
- MS, The redneck south -.-
Alright, here's my thought: I found this website that sells FFB1248SHE and EHE delta's for $4 each, the only problem is that they are 48v
http://www.excesssolutions.com/cgi-bin/item/ES2815 SHE
http://www.excesssolutions.com/cgi-bin/item/ES3393 EHE
(and there's a $25 spending minimum on the site, so you can get 6 for the price of... however many $25 will get you )
This site also has other Delta's (and all their fans) for $4 and $5 12v if you look, i'm gonna be gettin a 40mm just incase my chipset fan dies, a couple 80's and a couple 120's, but they dont sell FFB's in 12v or 24v. So is there an easy way to convert a 12v input rail to 48v that doesnt create too much excess heat? It be great if i could find all the parts on that site XD
Remember the converter will have to support an output of 48v at 0.6A
mmFFB
-prince
mmFFB
-prince
