SOLVED: Using the array in USB mode was hiding a NTFS problem
RAID: Standalone Hardware Raid Enclosure
http://www.sansdigital.com/towerraid-/tr5utplusb.html
Raid Level: 5
Drives : 5x Western Digital RE WD3000FYYZ 3TB
Operating System : Windows 7 Pro
Memory : 16 gb 1600mhz
Processor : 3.3 ghz AMD 1100T
Motherboard : Crosshair IV Extreme
GPU : MSI Radeon HD 7970 Lightning Edition
PSU : 1200 Watt Corsair AX1200i 80plus platinum
GPT Type
Symptoms:
After a circuit breaker trip, Windows 7 freezes when attempting to recognize the drive when it is attached.
It locks up until I unplug or power off the drive. Prior to sudden power loss drive was accessible.
When I unplug or power off drive Windows says drive is not formatted
Environment:
No UPS
Drive is connected to a surge protector and a GFI outlet
When power outage occurs GFI outlet will trip disabling power to outlet until reset by hand
(This prevents sudden surges when power is restored)
Drive temp are normal 30c
Trouble shooting steps:
Windows SFC - No change Problem exists
Complete OS reformat - No change Problem exists
BIOS Reset - No change Problem exists
Tried connecting with USB 3 / USB 3 / ESATA - No change Problem exists
Boot to Windows 7 PRO DVD - DVD also freezes when attempting to access drive
CHKDSK /f from Windows 7 PRO boot DVD - Reports drive as RAW
Windows 8.1 PE DVD - Can access drive and files No problem
Terabyte Unlimited Image for Lunix - Can access drive and files No problem
CHKDSK /f using Windows 8.1 PE DVD - NO ERRORS FOUND
Acronis Disk Director 11 - Recognizes drive No problem
Other USB devices work
Other ESATA / SATA devices work
Windows 10 PRO Install DVD Recognizes Drive no problem
CHKDSK /f from windows 10 Pro install DVD NO ERRORS FOUND
Lights on RAID do not indicate any abnormal condition (Array is not rebuilding)
I've tried giving it the finger and I've tried calling it obscene language
Both verbal and gestural persuasions have proven ineffective
Thank you for taking your time to look at this and for any advice that anyone could provide is greatly appreciated
Raid Level: 5
GPT Type
Symptoms:
Environment:
No UPS
