- Jan 5, 2005
Changing windows boot drive sata config from "raid" to "ahci"
So I have an AMD A88X motherboard in my htpc. For a few reasons I want to change the bios config for the sata controller from RAID to AHCI. I followed the instructions in this article: https://support.microsoft.com/en-us...er-you-change-the-sata-mode-of-the-boot-drive to have windows load the ahci driver, but now I can't boot. If I switch the bios option back to RAID, it boots fine. If I boot in safe mode, the system hangs on loading classpnp.sys then reboots (probably because it loads drive.sys right before). If I run the start-up recovery, it has no problem loading the storage drivers and mounting the drive since I can access it from the command prompt. What can I do to boot properly? I'd rather not reinstall windows. Doing a repair type installation is an option but I have to get a bootable USB drive so a simpler solution would be nice. Thanks in advance!
