Any help to clarify appreciated!
Am planning to use diskpart access from the command line in my Rufus boot USB as a first step to clean and format my destination drive
Plan on using these commands
clean
create part pri
active
format fs=ntfs label = 512Windows quick
1st question> SInce this will be my Startup or C drive do I need to use a label?
Next will reboot again into my Rufus USB to do a clean install of Windows
2nd question
SInce I've already formatted the drive I assume I skip and formatting options and just install?
Question 3
Knowing the above how do I configure my Rufus USB at the very beginning?
Question 4
Is there any advantage in choosing the dual UEFI + Legacy option (alt+E) ?
Question 5
Partitioning Scheme and Target System apply to the destination drive for the Windows install but the formatting options refer to the actual USB media and NOT the destination windows 10 drive.
Are these assumptions correct?
Thanks in advance!!
clean
create part pri
active
2nd question
Question 3
Question 4
Question 5
Thanks in advance!!
