I'm looking for a 160mm radiator template to drill the holes in u2 server cases. The Rad's are the Hardware Labs Black Ice Gen Two Xtreme Micro 160. I'm installing 4 of these rads and need to make 8 fan holes plus 32 screw holes and it would be easier with a template. I found a PDF for 92mm and 80mm fan template's from Mnpctech but I need a dual 80mm fan setup with a 15.5mm spacing. Something that I could print out like a PDF file instead of trying to cut out and tape the 80mm template's together. (Its the 15.5mm space between the fans mounting holes I'm having trouble with) I tried to copy the template in paint but I cant get the sizing right. Does anyone know of free software I could make this?
Thanks for any help
Thanks for any help
