- Feb 23, 2011
I'm looking to build a 1090T-based machine, with a 890FX chipset, with 16GB of RAM, at 1600MHz.
I am correct in assuming my only choice right now for running that much RAM at 1600MHz is the ASUS M4A89TD Pro/USB3? Of all the boards I've looked at, so far this is the only one that can support 1600MHz RAM modules WITHOUT overclocking the RAM. Isn't there a limit, usually, to what a board can handle, if you attempt to overclock the RAM? This board appears to support 1600MHz modules without that. I still want to crack up my 1090T to 4GHz, or whatever it can handle. As for dealing with the thermal issue, I wanted to try a Zalman CPNS9900LED.
As for the RAM itself, I was thinking about going with a 4x4GB Vengeance set from Corsair.
They are pretty cheap now, and I think it's more reasonable than ever that I could run a full 16GB of RAM.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7025816
I plan to use this setup for more than just gaming, as I do graphics/photography and I think I could benefit from having a huge amount of memory onhand.
