- Aug 23, 2007
Do you have room for a larger rad? A slim 240 is going to be cutting it a little short imho.
Looks to be a pretty good loop DaP. If you can fit the thicker PE 240mm radiators that would be preferred but if not the SE will do just fine. The only thing that I notice missing are the fans. You'll want something with a high static pressure as the SE has a high FPI (22). If you wanted to stick with all EK then the EK-Vardar F3 or F4 series are excellent choices. Note: The F4's do get quite loud when ramped up to full speed.
Thoughts? What have I left out?
I believe you need a male to male extension to connect the valve to the t-splitter.
It might be also good to have a plug on the valve, dont know if you already have a spare.
I think it depends on your plans with the card as well, as to whether the slim will work for you. I initially just slid my power slider to +50% in afterburner and then started cranking clocks. At 300w the card generated a ton of heat. Today I used an undervolt from OCUK and my power usage stays below 250 watts using 1.05v. I seem to get better performance than just increasing power slider and clocks. While my fans are by no means quiet while gaming with the loop in my sig (includes a 2600x and rad is a Hardware labs Black Ice Nemesis GTX 360, 60mm), they are at least reasonable.
If you're planning to use the LC bios with a 350w power target or even go further (through registry mods), then I don't know that you'll be in good shape with the slim.
