Hi all,
So, it has been a decade since I built a system. I have done a ton of research at this
point: to the point of burnout and confusion, and am ready to seek the advice of the folks
here who have current knowledge and experience.
The rig will be used to crunch data using BOINC: cancer research, climate change, SETI,
video editing, 50mb RAW files in Photoshop, and occasional gaming. I am looking to stay in a
tight budget of $1500-2000 so I'm not looking for bleeding edge: just reliability.
1. I have decided on AMD for the CPU: Threadripper 1950X, unless someone has a better
suggestion. I have read mixed reviews on its ability to overclock. It is used, never overclocked,
and I can get it for about $350.
2. Who makes the most overclocking friendly motherboard? ASUS, MSI, or others?
3. How many RAM slots are required to be occupied? In the past, some boards required Dimms
in pairs.
4. Who makes the most compatable RAM for an overclocked Threadripper?
5. Who makes a good case? $150-200 range or less. I don't care about LED's or aesthetics
all that much so if I can save money here I can apply it elsewhere. Size is not a
consideration as long as the motherboard fits.
6. Who makes a good power supply? Approximately 650-800 watts... Will it need more?
7. Who makes a good CPU cooler? I prefer to stay away from liquid if possible, unless
things have changed significantly.
Noctua 14S has decent reviews for air..
Enermax has OK reviews for liquid..
8. I can also buy two used Nvidia 1060's 6Gb for about $140 each from the same guy that the CPU
is comimg from.
Does that sound decent?
9. What have I "NOT" taken into consideration?
Thank you for any assistance. If you ever make it to Western NC, send me a PM and I'll
meet you at one of our brew houses and buy you a couple of rounds of your favorite beverage.
Best,
J
in pairs.
is comimg from.
Best,
J
