- May 12, 2004
- EU
EDIT: I've accidently posted this in the CPU section instead of INTEL CPU's section. I can't seem to delete this post (no permission). Could a moderatore please move this thread?
Greetings!
I've bought a new system a few months ago. Naturally, I've tried to OC it, since I've been doing that ever since my Celeron 333A.
I've been experiencing stability issues over 250FSB over the past two months. I've almost gone crazy while trying to find out what's wrong, but now I think that I've finally come to the bottom of things.
A few words about my system
For testing purposes, I've removed all but the very essential components of my system.
I'll try to keep this post as short and to the point as possible, so please bare with me.
System specs (stuff that is currently inside my case):
1) Enermax 460W PSU
2) ASUS P4P800 (unmodded)
3) P4 2.4C Q323A123 SL6WF with 1.525 vcore
4) 1 stick of Corsair 256MB VS PC3200 RAM
5) ABIT Geforce 4 Ti4200
6) Seagate 120GB 7200RPM HDD
Cooling for CPU & NB:
CPU heatsink: Spark 7's copper HS with AS-5 thermal compound
CPU fan: custom 80x80mm
NB heatsink: thoroughly cleaned stock HS with AS-5
NB fan: Spark 7's stock 70x70 fan @ 6300RPM - this fan also helps cool the CPU heatsing, as it is situated directly below the CPU fan
Ambient temperature: 20°C or lower
My case is completely open during these tests.
Overclocking and issues...
I use 2×PRIME95 with in-place FFTs for stability testing. To me, a system is rock stable if it can do at least 12 hours of 2×PRIME, F@H, ...
250FSB -> ROCK STABLE:
- vcore: default
- vdimm: 1.85
- vAGP: default
- divider: 5:4
- timings: 2,3,3,6
As I have mentioned before, I've been experiencing stability issues about 250FSB. I've discovered, that after I remove / disable a PCI card from the case, the stability increases (Skystar 2 DVB-S PCI card, onboard NIC, onboard SOUND).
The thing that has kept me puzzled the most is that:
a) increasing the vcore even to 1.65v does NOT change anything
b) fiddling with various settings doesn't help
c) fiddling with RAM dividers & timings doesn't make a difference at all
Read on!
260FSB -> Hmmm?
- CPU temp does not exceed 43°C
- System temp does not exceed 30°C
- vcore: 1.6v for testing purposes
- vdimm: 1.85v
- vAGP: various (see below)
- divider: 3:2 for testing purposes (I also tried 5:4 to no avail)
- timings: 2.5,3,3,6 for testing purposes
260FSB -> SYSTEM BEHAVIOUR:
- IF onboard NIC&SOUND are ENABLED, system will totally lock-up after 30 minutes of prime.
- IF onboard NIC&SOUND are DISABLED, the system will reboot itself after 60 minutes of prime.
- IF onboard NIC&SOUND are DISABLED AND vAGP is 1.80v, the system will reboot itself after 60 minutes of prime.
- I've noticed that if the onboard NIC&SOUND are ENABLED, increased vAGP helps the stability a bit (it adds a little time
before the system locks up or resets itself).
I think that my mobo is having severe issues. It can't handle mediocre FSB with stock chipset voltage and if any PCI cards are installed / enabled.
I have pretty much dismissed the possibility that the limit of my CPU has been reached, because:
a) 277FSB @ 1.575v: It boots into windows and performs all the tasks normally, except longer intervals (above 10 minutes) of prime and other similar programs that stress the system.
b) It reaches the WELCOME screen of WindowsXP at 300FSB with default voltage! After that, it crashes horribly.
In a) and b), my system was fully loaded (pci cards, 4 sticks of ram, cdrom, ...).
So since I've gone halfway mental because my system has been giving me gray hair for the past two months, I need you guys to either confirm or dismiss my theory that I HAVE A CRAPPY MOTHERBOARD.
If not, then what do you think that the problem is? Am I doing something wrong? What are the things that I haven't yet tried in order to solve this problem?
If so, the only solution I see is that I buy a new one.
Please don't hesistate to post suggestions or experiences with various motherboards. I'd definetly go for i875.
How are IC7 and P4C800 like? How do they fare with high FSBs? Do they cause any problems with enabled onboard features, etc.? Do all the i865/i875 motherboards experience vcore fluctuations (idle vs. load) until you do a vdroop mod or are ASUS mobos the only ones?
Sorry for the long post, but it's hard to squeeze two months worth of testing into one post . I'd really appreciate it if you'd try to answer most of my questions. Sorry for any typos, I'm trying my best .
GotThaJuice
Greetings!
1) Enermax 460W PSU
- vcore: default
- vdimm: 1.85
- vAGP: default
- divider: 5:4
- timings: 2,3,3,6
Read on!
260FSB -> Hmmm?
- vdimm: 1.85v
GotThaJuice
