bkny10555 said:I have two 8800GTX in sli and they seem really hot wasup with that
I need a way to monitor the temps on the GPU
Anyone else having this issue
1cem4n said:i'm getting around mid 50s on idle and around 78s on load. they run super hot and I don't even have a case on mine. I can't wait to OC them.
ViperJohn said:More "All in One" garbage.
Viper
While your post is entirely true, you forgot about the other 'kind' of watercooler. One that goes for silence. Watercooling the entire card eliminates the need for a fan on the card. Plus, I really doubt that the rest of the card could raise the temp by even a couple degrees (I'm thinking less than 1c).Elif Tymes said:Simple, the more parts your waterblock covers, the more it increases the water temperature of the loop, the less good of a job it does cooling everything else.
Your RAM isn't gonna get that hot. They won't be icey cold, but they don't need liquid cooling generally, unless you're going freakin' insane . Conversly, your GPU needs all the cooling it can get.
For most video cards, simply affixing some high end ramsinks + mounting a fan to blow over them will be more than enough for the RAM, and then having a dedicated GPU block for the GPU's will be most efficient.
Elif Tymes said:You can't have silence and highest end performance.
thideras said:How is that garbage, the cooler on the 8800's are that big for a reason, alot of components put out heat and need to be cooled.
thideras said:I sir do not believe that at all. With a well thought out and efficient setup, it can be quiet will being high performance.
